I think Bobs talking about farting eating the pork skin & tuna, so then you'll need to capture his methane output & use that for making the cup of tea.
You guys over think these things, go the easy route.
Found the methanol a few days ago at the Home Pro (less than 100 baht a can) and used it for the first time on cleaning purposes today.
Still need to do a burning test, guess it will burn well (if not a bit faster than ethanol?).
The difference in calorific value between methanol and ethanol is about 25%, ethanol having the higher calorific value.
Methanol has a higher vapor pressure and a lower boiling point, so methanol will burn easier but maybe a bit faster than ethanol.
The Hot Drink, Cup of tea or even a hot knoodle can have a huge Psychological uplifting effect when your stuck on a trail in the middle of nowhere dripping wet and cold and feeling sorry for yourself. It's just about possible with an Alcohol stove in any weather because the Alcohol will burn with a bit of water in it.
Marcel...in this heat, personally, I wouldn't carry this shit around in my loggege...let alone poor it and try to light it. I can tell you first hand that when some idiot plays with this crap and you stand near by...
you may end up like this:
Bob(S) nice stove but I frankly don't see the point of carrying that kind of weight around on a bike just for some hot soup...If I really feel the need to eat something hot I have matches and a lighter...worse case I can always dive into a muff![]()
I managed to get one of those bivy bags yesterday... tried it out today, much to the consternation of the dogs, who seemed to think I was in a bodybag. Its a ripper... and I'll carry it in Asia. 600 gms weight... a mini tent.
Picked up one of these at the same time.
Weight, 18 grams. Yeah, titanium.
I had a staff discount voucher. Wouldn't have paid the $30 retail for one.
More info on the bivy appreciated.thats not sold in thailand right?cheers
...how to store the methane gas from production to actual cooking (the so called gasholder, often a rubber balloon) and the actual pressure of the gas produced.3
..........and try that hot knoodle you speak of...but it might be difficult...........
Got one of those...but StainlessSteel...always worked well on a campfire.
In Canada in the remote places in winter I used to bring Alcohol Gel...packs a lot more cooking time for the same weight.
......... a Pigs Dick I can sort of understand.................
Alex, mine came with a rubber seal, it's about 10 years old max. When visiting friends in Piombino I could get replacement rings to suit for at least 10 more years!
As for cooking fuel, we can consider a gas form or a liquid form.
The fuel in a gas form requires a gas holder and a special stove designed for gas service.
Gas under pressure or gas under high pressure in a liquid form is highly combustible and in my opinion posses the highest risk.
The heavier fuels like petrol (Coleman) need a pressure system to reach the vapor pressure point high enough to ignite.
These fuels pose the least of risk (similar to the engine fuel) to ignite.
Methanol/Ethanol based systems require no pressure system, no high pressure container to use them, allowing the easiest form of a stove.
Agree that when handled carelessly these fuels are a potential risk, but than again.....any of the above do.
Looking at a packing system for alcohol, what about the widely available stainless steel mesh pots and pans cleaners found all over Thailand?
Alex - why are you burdening yourself with the weight of not one, but two corkscrews?..........BTW - this technique will disturb the sediment :-)....
Ultra lightweight spectra/ mylar backpack
28 liter capacityThe whole backpack weighs 260 grams and can carry 20kg !!! USD$ 79, great value.
A heavier dyneema/ spectra weave construction making it very abrasive resistant and super strong. The tops of the shoulder straps are usually what fails first, these with the dyneema weave are amazingly well made.
This is the same company that makes the cuben fiber tarp that i bought, you deal with the chap that owns the company and the quality of what he makes, is the best i've ever seen, link to the backpack below:
Mountain Laurel Designs
NEWT = Keep It Simple Day / Overnight / Weekend or Summit Pack.
One Torso Size: Fits from about 5'8" to 6'3"
20" - 21" from bottom of pack at waistbelt to where shoulder straps connect.
FEATURES
• All Dyneema X (TM) Construction: 210d Ripstop Nylon and Dyneema plus an extra X pattern overweave for high strength, lightweight and durability. (Much tougher and abrasion resistant than thinner and lower content 140d nylon+dyneema plain weave fabrics.)
• Roll top closure doubles as a compression system to stabilize and compact load.
• 4oz sq/yd Open Hole non Stretch Mesh. Stronger than stretch mesh twice the weight, easy to field repair, does not absorb water and drains fast and allows contents to dry faster than a tight stretch mesh or solid fabric. Dyneema X elastic top sleeves for long term Durability and elastic replacement.
• Shoulder Straps: 2.5" wide SuperWick Mesh lined with full length foam padding. Short daisy chain to fit pack shoulder pocket options.
• Load Rating: Strong enough for 30+lbs - But 14 - 18lbs is the recommended average max for all day comfort.
• Approx. External Dimensions 11" X 6" X 26"
• Sized for modern ultra light and SUL equipment. Great as an Apine Attack Style Climbing Pack.
• Six bungee cord loops use our removable mini fast clip hook system. The mini clips reduce bungee adjustment friction and bungee cord can be clipped/unclipped fast. Clips will not wear though like grossgrain and thin webbing. Hooks and bungee add about 1oz- not included in base weight.
• Removable Multi Position 3/4" Most Awesome Sternum Strap In The World with Black WistleLock Buckle + .5oz not incuded in base weight
• All seams double stitched plus stress points are quadruple stitched or bartacked.
• Haul Loop
Simple roll top, no zips, 100% waterproof
Quality fittings
Just got mine, it fits well, havn't tested it yet
https://flic.kr/p/pnBPFA20141207_080505.jpg by Triangle Golden 007, on Flickr
Minimum Weight | 11 oz / 305 g |
Packed Weight | 14.5 oz / 410 g |
Burn time (white gas) per 600ml / 20 oz. of fuel | 136 minutes |
Boil time (white gas), 1 liter | 3.9 minutes |
Water boiled (white gas) per 100 ml of fuel | 5.1 liters |
Water boiled (white gas) per 1 oz. of fuel | 1.5 liters |
Country of Origin | Made in Seattle, USA |
