Had been looking for these "hot patch" vulcanizing kits for a while and found one at SaengChai Panich in Chiang Mai, location:
https://www.google.co.th/maps/place...edddb8330!8m2!3d18.7958592!4d99.0057602?hl=en
Your supposed to use a special tire clamp to keep the pressure equal throughout the vulcanizing process, but a couple of vice grips would do the job.
Once the vulcanizing tin is clamped to the area that need patching (works on tires and tubes), you light the powder in the top of the tin.
Vulc by Triangle Golden 007, on Flickr
As the powder burns, the heat in the tin melts/ vulcanizes the rubber patch on the underside to the tube/ tire over the hole.
The whole box was 130 Bht?
Vulc box by Triangle Golden 007, on Flickr
Instructions:
Instructions:
