crs
As I've got an LC bike coming, was thinking about over heating problems... Anybody bother mounting rad fans (like 12v pc case fans) or running stuff like Engine Ice ?
http://www.rideasia.net/motorcycle-forum/bike-talk/1650-pull-fan.html
i also use Motul Motocool pre mix (locally available- Kwaker dealer)
Chris if you can get a fan mounted that will be well worthwhile. Another good thing to have installed is a coolant recovery tank. Basically a reservoir that catches any coolant spewed out of the radiator when the coolant boils and then allows the vacuum, once the coolant cools, to be sucked back into the radiator. After all, you only have to lose a couple ounces of coolant and you'll be running hot for the rest of the day until you can top off the radiator. The overflow tank keeps this problem in check. You can make one out of pretty much anything. Here's one I fashioned out of a brake fluid container that bolted to a cars brake master cylinder, cost about 80 bht. Just make sure your container is vented to allow the coolant to be sucked back into the radiator when cooled down. It's the white cylindrical container next to the GPS. One of these and a pull fan on the back of the rads should do wonders for you in keeping things running well.
I`ve heard of the computer fans lasting anything from a few days to Johnny`s year and more. They are fairly open to water being dumped in them.
I went with a KLX 250 unit on mine with a manual on/off switch and it works a treat.
Getting all posh on us now eh? I'm assuming your bike has a small 1/4" tube coming out of the top of the radiator near the cap. Simply route that line into the bottom of the brake master cylinder container. Or on the Motion Pro its the side nipple, not the nipple end on top of the bottle. Best of luck.Paul has got one of these spare, so having that of him. Which is handy...
Coolant Recovery Tank | Motion Pro
These tanks are shite! I used for about a year and had constant problems with the hose coming off the bottle. I also have a spare and it will not be going on any of my bikes.
They are also not very easy to put on the bike, space is a major issue - mine was in the airbox and was difficult to get the air filter on / off as a result.
I would just go with the fan and forget about the MP tank.
Using railway tracks | Bike Talk | 3 | ||
Synthetic motorcycle oil - best deals - what are you using in S.E Asia? | Bike Talk | 1 | ||
EJK Fuel Controller. Anybody using one? | Bike Talk | 19 | ||
Multistrada Radiator | Bike Talk | 13 | ||
Kawasaki KLX 250 (300) Cam upgrade mod | Bike Talk | 9 |
