USB multi charging point
johnnysneds
Today I fitted a multi-point charging system to the WR.
Ive had this now for a few years and you can get them from here:
http://www.locatis.eu
They've also got a lot of other handy charging accessories to suit your bike.
Its waterproof and has worked flawlessly on my other bikes.
I basically got it for charging my phone and camera when on the go.
Ive mounted it at the rear so I can charge gadgets in my rear luggage while riding.
The step down transformer will accept voltages between 10-30 Volts dc and output 5 Volts dc for all your electronic needs. Used Velcro stripe and secured it under my seat for easy access/removal.
The unit will supply a max current of 1.0 Amp and has an inline fuse of 1A as shown.
I was hoping I could operate my helmet camera while charging it at the same time, unfortunately it wont power up when the USB slot is being powered. Charging only. Im sure there will be a way to bypass this. Would be good to not worry about the battery expiring just before those special moments.
KTMphil Bike Talk 18
johnnysneds Bike Talk 13
H Bike Talk 2
