An unusual arrangement on the KTM 300 EXC's gear shift selector from a lot of other bikes. The gear selector lever/ pedal, has a female, conical spline, that mates with the male conical spline on the engine. A bolt then tightens the lever onto the angled spline creating a tight/ solid fit.
The problem with all the vibration and gear change abuse is keeping the bolt tight, its come loose about 10x even with Loctite
ktm 300 bolt by Triangle Golden 007, on Flickr
Have been experimenting in the past with 2 nuts on the threaded bolt. The connection where the bolt goes in is threaded, then one nut acts as a locknut, the second nut is a double lock nut, everything including the full length of the bolt is loctited. Hopefully this will stay tight.
If anyone has any ideas of making this bullet proof, please let me know, i've consiederd expoxying everything too.
You can see the two lock nuts in the photo below:
20150219_171516.jpg by Triangle Golden 007, on Flickr
