johnnysneds
- May 14, 2011
- Location
- Chiang Mai
- Multistrada 1200S Touring, WR450F, KTM200EXC, Gas Gas 280, PCX
Some useful info on Spark Plugs.
Most dirt bikes will use the "CR8E" rated Spark Plug. Ie WR's, YZ's, DRZ's, KLX's and many many more.
You will also be able to use a "C8E" and are 1/3rd of the price of the aforementioned. The missing "R" stands for resistor and the plugs with these eliminate frequency interference. You should be ok unless you have a TV fitted to your handlebars, but watch out if the better half phones you and your doing 250km/h
There is also the CR7E and CR89 which refers to the working temperature of the plug. The higher the number the lower the temp of the plug. Make sure you select the spark plug recommended by your bike manufacturer and the gap is correct.
Iridium plugs improve on performance but will burn out quicker than a stocker.
