During this year rainy season I decided converting my old (and little used) Giant mountain bike, which I brought over from Holland, with a Bafang 750W crank mounted electric motor and a 48V Samsung lithium battery. In future this will hook up with a solar panel experiment and maybe a small DYI power wall.
Ebikr in Bangkok is the Bafang agent and they have the conversion kits, eBike DIY - Ebikr and Facebook: ebikr.com อีไบค์เกอร์ จำหน่าย จักรยานไฟฟ้า มอเตอร์ไซค์ไฟฟ้า มอเตอร์ไฟฟ้า
Their communication (in English) via messenger is excellent! For example Ebikr did not recommend the (more expensive) 1000 watt Bafang unit due to strength issues with my bike having a 68mm crank bracket, fat tire bikes have a 100mm bracket which is suitable for a 1000 watt motor.
After ordering the kit arrived from Bangkok very quick and all components are indeed there, like the (conventional bowden cable) brake levers with the engine cut out switches.
I have been working on the bike on and off for a few days now, the battery is on as are the throttle, the screen with control panel but the motor is still on the ground.
Progress slows down now as I need a crank removal- and chain splitting tool so I can remove the original crank and front derailleur after which I can mount the motor in the crank bracket.
I will test it without the switched brake levers first, if needed I will mount these too but I do prefer the original levers......
Also the test will be without the gear shift sensor as this was not included in the kit, it's something I will add later.
![LRM-EXPORT-17282590556736-20190617-142426196.jpg](/motorcycle-forum/proxy.php?image=https%3A%2F%2Fi.postimg.cc%2FSxLvqzhw%2FLRM-EXPORT-17282590556736-20190617-142426196.jpg&hash=b6b5de596174fdc320157162c1a203e8)
