johnnysneds
- May 14, 2011
- Location
- Chiang Mai
- Multistrada 1200S Touring, WR450F, KTM200EXC, Gas Gas 280, PCX
OK using the baby bottle is a great idea to carry around 2T oil, however depending on which bottle you got means having to do some arithmetic at the pump when filling up and if your anything like me I probably calculate/subtract the wrong amount or you end up guessing a little. The contents go up in 25ml increments on the side of the bottle, my ml/per litre is 16.66 so you can see how confusing things become if you put say 3 litres in - 3x16.66 then subtract from 175 :bash Here's the solution:
Ill use the baby bottle I have as an example. I am currently using a 1:60 ratio premix which equates to 16.66ml per litre of fuel. You can use this online calculator at this link http://www.csgnetwork.com/oilfuelcalc.html to figure out your ml/ltr for the calculation
Now measure the full-scale of your babies bottle with a measuring tape. Here's my calculation:
250ml = 120mm
1ml = 0.48mm
16.66ml = 7.997mm
So i used 8mm per litre for simplicity when marking the bottle.
Now mark the amount of litres from the top down with your measuring tape/ruler in 8mm increments with a permanent marker. All you have to do now is note the amount of litres you just put in at the pump and use the litre scale on side of the baby bottle accordingly.
Ive actually modified the scale further and added another litre on top and marked it as "0" to avoid miss counting by one litre. Im also going to burn the increments with a soldering iron incase the permanent marker fades.
Im not sure how often folk change there pre-mix ratios but you could actually include additional scales around the bottle, remember though to mark each scale with the correct ratio.
And below is the finished product. No more head scratching for me at the pump :bash
250ml = 120mm
1ml = 0.48mm
16.66ml = 7.997mm
